Fatback
Surely someone you know has a dremel or something similar?
Nobody that I can think of off the top of my head but I will ask around.
This is the only pick I could find of the Xclio godspeed cable management
I like how he tried to wrap the cables around the drive cages lol
Edit: I have no doubt I can do better then that but there is just no way to hide the cables like I would won't to I like them to be nearly invisible.
Edit: http://www.youtube.com/watch?v=ht8od9l_6xs pause it a 4:16 in and you can really see how bad the cable management would be I do have a drill I would just have to get a bit big enough so I could fit the 24pin and molex connections threw.
I really like the godspeed but cable management is the most important thing in a case to me I like my cables to be very neat and unnoticeable. I might have to get it and just make it work or get a drill bit big enough to drill some 2 or 3 inch holes in the motherboard tray.
