Bleh with my multiplier settings at 2.40 and the voltage at +.2v prime95 got a error on core 3 within 5 seconds... so obvisouly this is wrong.. shall i go back to 2.00 and then bring the voltage back to normal and bring the timings to 4-4-4-12? when i do that i will need to increase voltage?
and yes i am using EVGA precision. So i should leave the shader and core clock and raise the memory clock.. how high u think i should go?
Hmm....yeah you can try it, I'd leave the voltage bumped though.
Well, I'd go right to 1100, see if it's stable, then maybe 1150, then 1200...etc.
Oh and I forgot yeah those temps are just fine, my gts250 runs in the low to mid-70's while game. Most GPU's can withstand up to 100c!
