ram voltages?
where can i find this info.. i added +0.2V to my ram in bios just wanna make sure im till under 2.2v .. my ram is rated to run at 1.9v - 1.9v non overclock. when i look at PC wizards voltage i am seeing DIMM 3.3v i am hoping thats not my ram
download CPU-Z
http://www.cpuid.com/cpuz.php
that shows you. On SPD at the bottom it has the stock vvoltages, just add + whatever you put on to it.
That doesn't tell you what it's currently running. Right now I have my ram set to ''normal'', which is 1.6v. According to CPU-Z it says 1.5v should be the normal. According to the ram I have, 1.5-1.6v are both ''normal''.
