About to order a CPU Cooler
Fatback
I'm not sure which ones are any good I only used a couple like the V8, Dark Knight, Zalman 9700 and 9900, pretty much all the ones above $40. I need something on the cheap side but something that is going to be better then stock. So here is the ones I have in mind.
Cooler Master TX2
Cooler Master TX3
Scythe Katana
Xigmatek HDT-SD964
I have measured and I now that all of them will fit my case. I have used the Xigmatek HDT-SD964 before and I really like it but I want to weigh my options first.
http://www.newegg.com/Product/Produ...233001&page=2&bop=And&ActiveSearchResult=True
Just go with the Xig. If you have used it before and it is reliable then why should you choose something else?
unless it is very expensive.
No it's not expensive it's only $25 so it is really cheap. I just wont to know if any of the other ones perform better before I order. I will probably order tomorrow so it will be here around Friday.
Any body else
The TX3 is looking really good right now if nobody has any suggestions I'm going to go with the TX3.
If anybody has anything to add now is the time. I'm going to order the TX3 tonight. I have been looking at reviews, and youtube videos and I am sure it will be good for my needs.
