PCI riser card?
Ok so I think I came to a conclusion? maybe?
how about a bigger case for the psu and since the heat sink is to close
a pci-e riser card?
Don't think the vid card would fit even in a new case and the wires were rerouted... from the looks of the position of the south bridge heat sink there isn't going to be enough space since the card covers 2 slots. The heat sink is going to interfere unless it is lower than the second slot. As for the PSU a different case would solve that problem but probably not the new vid card.
Actually I believe it will fit. My 4850 is right over my southbridge and has plenty of room. That heatsink doesn't look that tall and if he measures it and tells me the hight of it I will be able to tell him if it will fit. Ok I just measured my soutbridge HS and it is 1.5cm tall and my 4850 has plenty of room to fit.
Your 4850 is a single slot design... Go look at the pictures of this beastie (Geforce GTS 250). It is a two slot design and way wider than your 4850.
No my 4850 is the XFX one and it is dual slot and is just as big as a GTS 250 the GTS 250 and 4850 are almost identical in performance. I have been upgradeing OEM computer for a while now and I never came across a motherboard that would not fit a graphics card.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150337
There are pics of my rig on my profile if you wont to see it for your self.
You didn't specify it was XFX originally. Be that as it may without measuring the height of the south bridge HS, as you said, there is no way to tell for sure. It may very well fit but I can't tell that from the pictures he posted.
I'm sure you also noticed the MB mounted left handed instead of right handed with the slots on the top instead of the bottom in that shot. Given that there would possibly be interference from the drive bays, even if the PSU would have fit in that case, space and wire management would be a major issue.
Yes, if the HS is no higher than the slot in front of it then there won't be a problem in another case that the PSU will fit in. The pictures posted and the ones from HP are deceptive and don't show the actual height of the HS in reference to anything else.
Thus my hesitation in saying to the man, yes it will work.![]()
The hight of the heatsink is not going to be the problem neither is the motherboard being mounted left handed. From the picture it looks like the GPU is going to hit the ram slots but that cant be since he already has a graphics card in there. If we could get him to take some better pics of his computer without all the cables in the way. We would be able to decide weather it would work or not.
Ill take a picture of that later on today.
ANd yea now that I think if it I don't think I was having a problem with it hitting the heat sink it was mainly the wires I believe.
Ok so these were the best pictures I can get. I really tried not to take out all of the connections and just move them out of the way because some are hard to take off like the mother board main plug.
Yes but the new casing still has that front wires issue
Also I hope someone can reply on a good Vid card to get that will suit that "HP"![]()
