Yes, assuming you mean the MSI P55-CD53
Try booting with only one stick of RAM in the first designated spot.
If that fails, try the other stick in the same slot.
There's also an EDIT button on your previous posts, so you don't
have to Double Post. :good:
Did you plug in the 4pin CPU Power Connector?
http://www.newegg.com/Product/ShowI...CD53 LGA 1156 Intel P55 ATX Intel Motherboard
Its a common mistake and I meant no disrespect.LOL no i missed that onethanks
