Folding@Home: CF Official Discussion Thread
You plan on buying one? They will be expensive:(
They will be great Folding cards I am sure:D
Weak US dollar = win for me. I'm just going to get it from newegg and have it sent here. :D
I'm sure they will be great for folding. On paper they look powerful.
ScOuT, where did you download that FAH program? I can't find it on the list in the sigs. Is that an update or something?
http://fahmon.net/
It's a small program that tracks your Folding stats. It's great...as long as I Fold...FAHMON will be running.
It can be a little tricky setting it up...let me know if you have any issues and I can walk you through the process.
http://fahmon.net/
Ok, I installed it, and when I go to Add New Client, do I select the FAH under program files in Windows Explorer?
1. Download and install
2. Open FAHMON and click on "clients" and then select "add new client"
3. You'll then see a box like this
4. As the picture states...type in a name and then paste the log file file location. To find the log file location start your client, right click the icon in the task bar, highlight status and then go to "Log File...you will see some thing like this.
Then you have added the client:D
****Sorry about the slow response...took me a couple minutes****
For FAHMON? I can't even tell a difference between idle and when FAHMON is running...it uses almost nothing really.
mep916 turned me onto FAHMON and I love it. As soon as my computer comes on...FAHMON is running:)
Should I make it so that it distributes throughout all four cores or should I keep it to one core?
all four cores. You gotta use the SMP client and enter the -smp flag when you install the app. There's instructions at the folding forum and I think Scout wrote up a quick guide in this thread.
After a long overdue haitus...Im back in the game. Wanted to wait til i got onto water for my cpu because the S1283 wasnt keeping my quad cool enough for my taste. 50C load while folding however makes me very happy:D
About time...nice to have you back:D Did you get your eVGA bucks? You are Folding for CF now right:confused:
Yeah, folding for CF. I stopped folding over a month ago because of my CPU temps being too high for my liking and now just started folding again.
Sweet...we need you!
I was looking at the new water loop you installed. I was thinking about it also, but, my wife will have my computer for a year. I did think it was a good idea.
50c while under full load is great...run that SMP like a mad man:D
I finally got SMP running again...ahh...it feels good. And temps are great for air:D
