This is no biggie just curious why theres such a long delay on start up (over 2 minutes) after the BIOS screen before the windows logo appears, anybodys elses do this? Is there a fix??
Hm. Do you have a lot of programs running at startup?
Go to Start> type "run"> type: "Msconfig", go to the Startup Tab and unselect everything that's you don't want to start up. That should help a bit. Make sure you don't unselect any Windows services though Also, on that same box, go to the "Boot" tab and the click on "Advanced Options", Turn on ALL four of your processors (Assuming this is your rig specs in your signature) and type in the amount of Mb's of RAM. The press OK and restart and see if that helps you any.
