Formatting 1TB HDD
voyagerfan99
Is there any way to format a 1TB drive and try to prevent such a large loss of space upon format?
It's called marketing. There is no loss of space, the drive simply does not have as much space as advertised. It's the whole 1000 bytes = 1024 bytes deal.
I really wish that when they advertise drive space it should say:
"250GB*"
where * goes to this:
"*232GB actual storage space"
Or they could just make HDD's that use proper space (1024b instead of 1000b)
Yeh the higher you go the more you lose :D
You always feel a bit ripped off when you buy a new drive. :(
Well in any case the shell shocker on Newegg is a 1TB WD Green for $75, which I consider a steal, so I bought one.
Yeh, technically your not loosing any space but you need to realise the difference beetween a gigabit and a gibabyte ;)
