Enjoi
banned
After you get your new card, you can prolly RMA the 8800 gt. It should be under warranty.
I voided it trying to fix it. Lesson learned.
[YT]rX7wtNOkuHo[/YT]
If I were you I'd invest in new GPU, maybe small upgrade to 9800GT, which runs colder than 8800GT. Or go for something better, GTS 250 maybe???
A 9800GT is the exact same thing as an 8800GT, it runs no hotter or colder. A GTS 250 would be also a very small upgrade, it's equivilant to a 9800GTX+ or 8800GTS 512MB.
BTW, i broke 4850 changing the cooler, I wish you luck
No offense, but changing a cooler isn't rocket science.
