larry1140@yahoo.
I keep getting a virtual memory alarm.
what do it mean
what do it mean
need more memory.
its using your hard drive for memory now.
its cheap enough.
ya could try going to start, run and 'msconfig'.
on the start up tab you could uncheck everything
you don't need running. ya don't need ms office products or
adobe running. you can double click it and start up as needed.
you can always go back and turn it back on for start up.
I heard that your page file should be 1/3 bigger than your actual RAM. eg you have 2gb of ram so your pagefile should be 3gb
thank you all for your help. this is a built from old parts special. just your basic web surfer. nothing fancy. the virtual memory alarm threw me because it had not been an issue in the past.
good luck to everyone!!!
I have two gigabytes of RAM in my system and have my page file set at 384 megabytes. My system runs great with these settings.
