Nekka-Lucifer
Ok, me again. I just need to know whether this is a good build or not, if there is anything else I should get for same price range. It has to be at http://www.scan.co.uk !!!! Also, if theres any problems with the build as to why it wont work as well, please tell me. Thx.
PSU - EA-650 GB - 650w Antec EarthWatts 120mm Low Noise, 80 PLUS® certified,6 Sata ,2 PCI-e - £64.94
http://www.scan.co.uk/Products/650w-Antec-EarthWatts-120mm-Low-Noise-80-PLUS-certified6-Sata-2-PCI-e
CPU - HDZ955FBGIBOX - AMD Phenom II X4 955 BlackEdition, Sok AM3, 3.2GHz, 8MB Total Cache, 125W, Retail -£127.13
http://www.scan.co.uk/Products/AMD-...ion-Sok-AM3-32GHz-8MB-Total-Cache-125W-Retail
MoBo - Asus M4A79XTD EVO, AMD 790X, AM3, PCI-E 2.0(x16), DDR3 1333/1600/1800, SATA 3Gb/s, ATX - £82.77
http://www.scan.co.uk/Products/Asus...-DDR3-1600(OC)-1333-SATA-II-SATA-RAID-ATX-VGA
HDD - 500 GB Western Digital WD5001AALS Caviar Black, SATA 3Gb/s, 7200rpm, 32MB Cache, 8.9 ms - £42.55
http://www.scan.co.uk/Products/500-...viar-Black-SATA-300-7200-rpm-32MB-Cache-89-ms
DVD Burner - Sony AD-5240S-0B 24x DVDR 12xDVDDL DVDRW x8/-RWx6 SATA Black - £15.74
http://www.scan.co.uk/Products/Sony-AD-5240S-0B-24x-DVDR-12xDVDDL-DVDRW-x8-RWx6-SATA-Black
RAM - TW3X4G1600C9D - 4GB (2x2GB) Corsair Dominator DDR3, PC3-12800 (1600), 240 Pin, Non-ECC Unbuffered, CAS 9, DHX - £84.74
http://www.scan.co.uk/Products/4GB-...0-(1600)-240-Pin-Non-ECC-Unbuffered-CAS-9-DHX
GPU - HD-577A-ZNFC - 1GB XFX HD5770, PCI-E 2.0(x16), 1200MHz GDDR5, GPU 850MHz, Cores 800, 2x DL DVI-I/HDMI - 126.01
http://www.scan.co.uk/Products/1GB-...z-GDDR5-GPU-850MHz-Cores-800-2x-DL-DVI-I-HDMI
Case - RC-330 - Coolermaster Elite 330 Blk/Silv Midi Tower Case w/o PSU (New Improved Version) Scan Exclusive - £27.93
http://www.scan.co.uk/Products/Cool...w-o-PSU-(New-Improved-Version)-Scan-Exclusive
GPU has to be XFX
GPU has to be XFX
