4650 his 1gb graphic card problem
sounds like atrifacts. Whats the GPU temp running at. Artifacts come form too much heat and or overclocked too much.
You click on the meter with the -/+ at the left and it shows what the voltage and temps are. What do you mean by you installed it on ( your other computer).
well i dont have the computer right now but i need to gget it fix before tomorrow afternoon.
so i assume it is over heating how can i fix the problem?
turn down the gpu in the bios?
On the contrary, CCC doesn't show me fan speed options, i had to set them in rivatuner.
all ati cards i have had an option to enable manual fan....
but on closer inspection it seems like that option is not available on anything bellow 4800 range
WEll heres the fix to that.
GO into the registry editor and do the following
FanSpeedPercentActual_NA
FanSpeedPercentTarget_NA
FanSpeedRPMActual_NA
FanSpeedRPMTarget_NA
Find these enteries and change the default "1" to "2
This should enable fan control in CCC
If the above down work in registry editor do This. Its the same.
Make a profile in catalyst after turning on Overdrive and make sure clock and memory settings are correct.
For Vista
Then go to the following location and open the following file for editing "C:\Users\Your Windows ID\AppData\Local\ATI\ACE\Your CCC Profile.XML. The xml file will have the same name as the Catalyst Profile you saved. right click and hit edit.
For XP
Then go to the following location and open the following file for editing "C:\Documents and Settings\Your Windows ID\Local Settings\Application Data\ATI\ACE\Your CCC Profile.XML. The xml file will have the same name as the Catalyst Profile you saved. right click and hit edit.
Now go down the page until you see the following lines in the XML file ...
<Feature name="FanSpeedAlgorithm_0">
<Property name="FanSpeedAlgorithm" value="Automatic" />
</Feature>
<Feature name="FanSpeedRPMTarget_0">
<Property name="Want" value="0" />
</Feature>
<Feature name="FanSpeedPercentTarget_0">
<Property name="Want" value="23" />
Change the "Property name="FanSpeedAlgorithm" value=" from "Automatic" to "Manual"
Then change "Property name="Want" value=" from "23" to your desired fan speed.
Save the file then reload the Profile you just edited in the CCC.
You will have to select the profile everytime you re-start the computer.
Be sure to also set:
well it was the graphic card shit wasn't even over heating so i assume it was a defect,so i bought the same kind of graphic card at micro center and swap them out and it fix my problem.
