$1000-1200 Desktop Computer
Linck
Hi guys, Im new here and i wanted to ask you guys whats the best Gaming Computer i could get for $1000 (Or a little more)
I dont know much about hardware sooo, Im scared that i will choose incompatible/bad components.
Any help please? :)
Ive got this list with components for a computer... I dont know if its a good setup or something, Or if the components will be compatible with eachother.
Here it is:
The less important thing for me is the Sound Card, I have only 2 speakers and I dont care much about super quality audio :P
I feel a little insecure about the list... I dont trust myself since its the first time im gonna build a PC, I just chose what i thought was best for an affordable price.
I also dont know if i chose good things.
Any help would be GREATLY appreciated! :D
Thanks
Don't buy things from bestbuy, they have really bad prices. If you can order online, use www.Newegg.com.
As for the soundcard, do you have a good pair of 2.0 speakers? If you do then it's a good investment, if not, then put the money else where.
Also I would look into another power supply. Rocketfish isn't exactly the best brand. Look into Corsair or something.
Cooling wise, don't get those cheap all in one water cooling kits. They often perform worse than high end air coolers.
I wouldn't waste that i7 on an H50 bud. If you want to do watercooling, you have to downgrade some parts to stay in budget.
As said before, if you go to newegg, your price will go down while performance increases. There you can get a much better motherboard that has hi-def audio on it. Trash the sound card unless you're a music freak.
Really, once you get to NewEgg and edit your parts list, you'll have a much cleaner and cool build.
Post once you're finished.
Try newegg.com, they should be cheaper.
Motherboard - go for Asus/ Gigabyte. Intel mobo is not very good.
RAM - 2 x 2GB is what you need. P55 support dual channel.
PSU - I personally haven't heard of Rocketfish... I would go for well known brand like Consair/ Antec/ PC&C / OCZ/ Sliverstone/ Seasonic, etc.
Cooler - that one looks expensive...
HDD - Western Digital Caviar Black should run faster.
Yeah most people use newegg and never have a problem with it
also if your not to fixated on intel look at an amd processor, theyre cheaper and perform well for the money.
heres a list for you.
processor:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103704
mobo:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131382R
RAM:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231283
X2 if you can
HDD:
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148469
GPU:
case:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129058
dont know if you have one yet so i though id list one anyways.
PSU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139004
Total: 774.88 (w/ 1 of every thing)
and mobo, psu and gpu are all crossfire ready so if you wanted to you could.
phenomII X4 versus i7 for gaming
Why is everyone fixated on i7 cpu's for gaming. The amd PhenomII X4 far out performs the i7 when overclocking in gaming. The amd 955 and 965 black editions can be overclocked to nearly 6ghz with the right cooler and mb. The i7 overheats very easily, you would be lucky to get mid 4's without problems and forget about geting over 1.5 volts
Where do you get your stats?
So you are saying that there are coolers for average user that will take u to 6ghz ? Link pls. LOL
Sorry for the late reply, I was at Miami for a few days...
Alright, I built another PC, But I dont know if everything is compatible/good.
Processor:
Intel Core i7-860 Lynnfield 2.8GHz 8MB L3 Cache LGA 1156 95W
$289.99
Video Card:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121308
ASUS EAH4890/1GD Radeon HD 4890 1GB 256-bit GDDR5 PCI Express 2.0 x16
$214.99
Power Supply:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80
$109.99
RAM:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220373
Patriot Viper 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 2000 (PC3 16000)
$158.99
Hard Drive:
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136283
Western Digital Caviar Black WD7501AALS 750GB 7200 RPM SATA 3.0Gb/s HDD
$69.99
Cooling:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118046
ZALMAN CNPS9900LED 120mm 2 Ball CPU Cooler
$52.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16835150007
MASSCOOL FD08025S1M4 80mm Case Fan
$1.99
Motherboard:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131404
ASUS P7P55D LGA 1156 Intel P55 ATX Intel Motherboard
$149.99
Toal: $1048.99
Updated The List:
Processor:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
Intel Core i7-920 Bloomfield 2.66GHz 4x256KB L2 Cache 8MB L3 Cache LGA 1366
$288.99
Video Card:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102856
SAPPHIRE Radeon HD 5870 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP
$399.99
Power Supply:
$109.99
RAM:
$158.99
Hard Drive:
$69.99
Cooling:
$52.99
MASSCOOL FD08025S1M4 80mm Case Fan - Retail
$1.99
Motherboard:
$149.99
Total: $1232.99
Im not sure about the Processors, one is i7 920 (2.66 GHz) and the other i7 860 (2.8 GHz)...
Also, Do i need a soundcard with that Motherboard?? :S
First of all, i7 920 is socket 1366, so you need to get X58 motherboards instead of P55 if you want to use that processor.
i7 860 is faster at stock speed and consume less power. But i7 920 would better for Crossfire because it supports x16/x16
If you plan to get i7 920 then 6GB (3x2GB) would be the ideal ram because it supports tripple channel DDR3
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148253
Core i7 920 goes with LGA 1366
Core i7 860 goes with LGA 1156
HD5870 seems like would put him over his budget
$288.99
$289.99
You only save like $54 so you could get an HD5850 but i'll cost him a little extra
$288.99
$289.99
Ill buy the i7 860, Its faster & I dont plan to Overclock it or anything (IDK how to do it)
Also, I already had the HD5870 in he (2nd) list :P
