which proccessor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103706
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103694
quick answers ordering soon please
im kind of torn btw the 2 proccessors I mean my friend says its best to have more ghz per core than more cores.
So overall what do you think would get better frame rate with cod4
On the video card...
It costs less than the 4850 ill definately sub that in thanks
im gonna go with the 3.0 dual core because it seems like it would be better for what im trying to do
(light gaming and after effects)
For light gaming, you really don't need that much. For After Effects, you will definitely see a boost with a Quad core over a Dual core. While Mhz over cores especially was important when programs weren't optimized for multi-core, now it isn't a big deal.
You can still get the dual core, but for what you're doing, a Quad, IMO, would serve yor needs better. That 4870 will be amazing and you won't have any issue with gaming.
