V vieya Member Nov 12, 2009 #1 I typed in google.com and then it went to piraty.com. I must have a virus. I guess it's time for a format. Anyone heard of this?
johnb35 Administrator Staff member Nov 12, 2009 #2 Follow this procedure and post the requested logs. http://www.computerforum.com/131398-important-please-read-before-posting.html
Rambo New Member Nov 12, 2009 #3 vieya said: I typed in google.com and then it went to piraty.com. I must have a virus. I guess it's time for a format. Anyone heard of this? Click to expand... Someone may have just edited your HOSTS file so every time you enter google.com it redirects you to piraty.com. Google it. Oh wait, you can't Have a read here and see if that's the case...
V vieya Member Nov 12, 2009 #4 i forgot to say this isn't my computer it's my sisters and it runs windows 7 is that the same? btw the google works. the first time I typed it in though that's where it redirected. it worked after that first time. Attachments hijackthis_.txt hijackthis_.txt 8.7 KB · Views: 165 Last edited: Nov 12, 2009
Respital Active Member Nov 16, 2009 #7 vieya said: yes it remove backdoor.bot and svc...?.exe Click to expand... Please post the log from malwarebytes' and; Download the HostsXpert. Extract the HostsXpert.zip by doing the following: Right-click HostsXpert.zip and select extract all – Follow the wizard and extract it to your Desktop Click Finish, double-click the HostsXpert folder and then double-click HostsXpert.exe Press Restore MS Hosts File and press OK. Exit the program. Note: if you were using a custom Hosts file you will need to replace any of those entries yourself.
V vieya Member Nov 17, 2009 #8 here is the malwarebytes log it says there's an error when i try to restore ms host file. Attachments mbam-log-2009-11-12 (14-46-10).txt mbam-log-2009-11-12 (14-46-10).txt 1.1 KB · Views: 42 Last edited: Nov 17, 2009
