The Astroman
OK, I have a problem.
I've bought a new PSU, which I want to couple with an old one for power purposes. I was thinking of using the new PSU to supply power to the motherboard, my SSD drive and a bit of the GPU (6-pin), while using the old one to power fans, HDDs, CD-DVD drives and a bit of the GPU (8-pin).
My case, Cooler Master Stacker STC-T01, is made to house two PSUs, and comes with a dual power inverter:
However, here is the problem: the inverter uses 20-pin power, where my motherboard needs 24. My old psu has 20pin and plugs into it no problem, and I can plug the 24pin of the new PSU on the female end of the power inverter (with 4 pins unattached), and I can plug the power inverter into the motherboard, but 4 pins remain to be "filled".
My build is
Intel Core i5-750
Asus P7P55D-E EVO
OCZ SSD Vertex Turbo 30GB and existing 180 GB SATA HDD
Sapphire HD 4890 Vapor-X 2 GB
Noctua NH-U12P SE2 CPU cooler
Corsair Domintor DDR3 Ram
The new PSU is an Enermax MODU-82+ 525W and the old one is a 350W Enermax.
a) Is there a way I can use the dual power inverter and somehow fill the last 4 pins unattached on the motherboard (using the 12V 4 pin maybe) or do I have to buy a 24 pin dual power inverter (such as this?
b) If there is no way to use these two PSUs at the same time with that power inverter, would the 525W Enermax be enough to power the system on its own? It has the following specs:
My build is
Intel Core i5-750
Asus P7P55D-E EVO
