Looks like it still does, as far as price/performance goes.
Intel
http://www.newegg.com/Product/Product.aspx?Item=N82E16819117176
AMD
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103689
The Xeon may be 2.5 times the price, but it will smoke that opteron. The opteron is just 6 deneb cores stuck on the die. Lame AMD. Plus the Xeon will overclock much further.
Because that's what you do with server cpu's.... overclock them.![]()
Same here, but if i had a server cpu in my desktop id definately overclock it, the lower stock voltages allow for greater voltage headroomI would never over clock a server ever...
But how would it fare against TWO of those opterons?
edit: Woo 100th post!![]()
No you wouldn't, at least if you had common sense. You want the server to be as reliable as possible, especially since most are run 24/7.I would![]()
[-0MEGA-];1382600 said:No you wouldn't, at least if you had common sense. You want the server to be as reliable as possible, especially since most are run 24/7.
We are just talking about server CPU's here, that doesn't necessarily mean it has to be in a dedicated server. Lots of people use server CPU in their PCs.
