Fatback
Horrible for air, great for water. Excellent cases...gigantic aswell.
Huge they are, I'm don't really like the look of them but for the quality and size I could care less about the looks.
Actually im going to use them in my test box for my TIM testing, i need not only consistant ambient temps but also a consistant airflow.Or send them to me![]()
Not being rude but i dont need to be told how to run my own testIf you want really constant airflow, you should use the fan as a pull fan because the airflow is smoother than after it's been chopped through the fan.
Not being rude but i dont need to be told how to run my own testI already chatted with some guys from arctic silver and while they dont support testing they did give me alot of good variables and such that need to be controlled. And actually the intake of a fan is more turbulent to a degree, while the exhaust is uniformly circulating.
BOOM! roasted
Aerodynamically there is quite a bit different between a 120mm .47A fan and four 4500 horsepower engines with 13.5ft propellersHey, man, it's just a suggestion. And what I meant is the general speed of the air, not so much the direction. So if it's taking in air, the air is coming to a general point instead of emanating from a general point. (My dad flew a P-3... he's sorta telling me what to type :/ )
Aerodynamically there is quite a bit different between a 120mm .47A fan and four 4500 horsepower engines with 13.5ft propellers![]()
Not for this test, but i may make a mini wind tunnel out of one of the delta's im going to buy and do that.you should do that thing with straws like the did on mythbusters(i think think they took a box of straws and cut it in half then placed it on the exhaust to get even distribution) actually, i think it's called a honey comb? or something like that anyway
Painted the inside black, cleaned up the rear fan grille and added another R4 to the rear, and did a little cable management: (Yeah, i know i need to touch up a few spots on it)
