shamimmirza
Please suggest me a better choice between these two cards:-
Nvidia GTS 260 or ATi Radeon HD 5770?
Thanks in advance
Thanks in advance
So, which one would be a better choice keeping in mind DirectX 11 support?You mean a GTX 260? Straight out performance the GTX 260. But the 5770 is a newer directX 11 card. The 5770 is slightly slower then the 4870.
But overall which one would be a best deal?5770 supports DirectX 11. The GTX 260 does not support DirectX 11.
Thanks everyone for your helpful responses.Both will plow through any game out at the minute, however because of the DX11, I personally would go with the 5770 so you know that when a DX11 game comes out, you can utilise it (that is until the 5770 becomes outdated).
However, if you are happy playing in DX10, then I would go for the 260, because it has more power.
But, with that said, if you have a board with crossfire, go with the 5770 so you can crossfire in the future if you want; that will make it slightly outperform a 5850, which jumps all over the 260
