AceSpade77
Ive had a bit of confusion choosing a mother board for my new gaming build, and the one i ended up choosing takes DDR2 but it says this in the specifications:
Memory
-Number of Memory Slots 4×240pin
-Memory Standard DDR2 1200(O.C.)/1066*/800/667
-*Due to AMD CPU limitation, DDR2 1066 is supported by AM3/AM2+ CPU for one DIMM per channel only
-Maximum Memory Supported 16GB
-Channel Supported Dual Channel
The "Due to" area has me confused, i would like to run 8 Gigs of this:
Kingston HyperX T1 Series 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model KHX8500D2T1K2/4G - Retail
But this is 1066 ram sticks and up there in the "Due to" area of the mobo description has me confused on if this will work.
Please let me know if you know if 8 gigs of this ram will work on this mobo
Thank you..
Memory
Thank you..
