Rename it to 900.ROMthe file name is "900-ASUS-1004.ROM"
Excellent! I had the same issue with mine, it had to be manually renamed to 1000.ROM. Not sure why though, but at least it worked.yes it did thank you the reason why it took ages coz the meory stick didnt work with it so i put it on another meory stick and instead of taking ages to load it worked fine
