Ive been looking for something comparable to the 4890
would this fit? http://www.newegg.com/Product/Product.aspx?Item=N82E16814131327&cm_re=5770-_-14-131-327-_-Product
It also comes with dirt2.. like a 20$ game?
is this a deal or what?
Yeah that would fit,Any Pci-e card will fit
Its a good deal,the 5770 isnt as powerfull as the 4890 though remember that,so its up to you...spend a bit more and get a better high end DX10 card (4890) OR spend a little less and get a lower end DX11 card (5770).
but that doesnt mean the 5770 is weak.....your call
