Split movie on 2 discs?
C_Man
I have a file on my computer that is to big for the dvd disc's I have. I dont want to go out and buy 8.5gb discs I rather just split this file onto 2 disc's. Can I do this easily on any program or is it just not worth it? I looked back at the file and it is just over six minutes too big. I am thinking some how I can cut out just enough time so it can fit. Whats would be my best option. I have nero and windows dvd maker, All that stock crap windows 7 came with.
Try the Dual Layer or Double Layer DVDs and burn it with NERO.
Hope that helps
Hope that helps
do you have any dvd file converters? you could make it a little bit lower quality and it should fit
well he can create a iso with it,mount it and use an DVDx 2.2 and RIP it to AVI...
if its a moie that we ar5e talking about that was copied to the computer without being compressed...
next time use DVD shrink 3.2...;)
