I decided to build a pc from ground up. Two main reasons being 1. I've always wanted to do it and 2. I can afford a much better computer if I buy it piece by piece (I can't save money worth a shit). So I went to NewEgg.com and pick out all the components. Now not knowing shit about building a computer a got two questions. 1. How many watts of power do I need and 2. Looking to build the best computer I can for the least amount of money can you guy recommend some components that will give me the same amount of performance or maybe a little less for less money? The bill for what I've pick out is $2,491.84 before shipping so it needs to come down a bit. But I still want a sickass pc!
So here is what I have picked
Thermaltake ArmorPlus(Armor+) VH6000BWS Black Aluminum / Steel ATX Full Tower Computer Case - $187.99
GIGABYTE GA-MA770T-UD3P AM3 AMD 770 ATX AMD Motherboard - $84.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133056
XFX HD-587A-ZND9 Radeon HD 5870 (Cypress XT) 1GB XXX Edition 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported - $437.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128392
Hauppauge WinTV-HVR-2250 Media Center Kit Dual TV Tuner 1213 PCI-Express x1 Interface - $129.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16815116036
AMD Phenom II X4 965 Black Edition Deneb 3.4GHz Socket AM3 125W Quad-Core Processor Model HDZ965FBGMBOX - $179.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
G.SKILL Ripjaws Series 4GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9S-4GBRL x 4 sticks - $759.96
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231313
Western Digital Caviar Green WD20EARS 2TB SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive - $189.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136514
Pioneer Black Blu-ray Disc/DVD/CD Writer SATA Model BDR-205BKS - OEM - $199.99
HP 24X Multiformat DVD Burner Black SATA Model 1270i LightScribe Support - $30.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827140041
ENCORE ENLWI-NX2 PCI Wireless Adapter - $29.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16833180058
Arctic Silver 5 Thermal Compound - OEM - $19.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16835100008
Tuniq CR-PRO120-BK 120mm Magnetic Fluid Dynamic Bearing Propeller 120 CPU Cooler - $59.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16835154009
Microsoft Windows 7 Ultimate 64-bit 1-Pack for System Builders - OEM - $179.99
Everything is on newegg.com if you need to check out stats
PLEASE HELP ME!
PLEASE HELP ME!
