bomberboysk
It's not coming from the fans, it's from the CPU block. I can just have the pump on and it will still make that noise.
I have taken it apart twice and there is nothing inside. Sometimes it's not that bad, other times it is worse =S
Sounds almost like it isnt bled properly and has some air in the block. the block needs to be taken off the cpu but still attached to the hoses, and then place it so the base is horizontal and leave it like that for an hour or so to remove any air bubbles in the cpu block. If that doesnt work....contact swiftech.
Also....make sure the inlet and outlet are setup correctly. The inlet should be the lower barb, and outlet the higher barb.
Whats with the T-line? You shouldnt need a t line for a single loop, should have the tubing going like this with no extra fittings: Pump Outlet->Radiator->CPU Block->Back to Pump.
