J Jamin43 banned Mar 5, 2010 #1 I'm running an EVGA 9800 GTX+ and having trouble with a game install. How can I confirm that Direct X 9 installed on my PC. Thanks
lubo4444 Active Member Mar 5, 2010 #2 Go to start menu and go to run command and type dxdiag and press enter. A window should pop up and on the system tab on the bottom it says what version of DirectX you have.
lubo4444 Active Member Mar 5, 2010 #4 Ok when you open your start menu where it says "search programs and files" type dxdiag and press enter. I'm also using win7 and when i type it, it shows what version i'm running.
lubo4444 Active Member Mar 5, 2010 #7 hahaha i've read your post before you edited it, yeah you are running DirectX 11. You should be good to go.
J Jamin43 banned Mar 5, 2010 #8 Right, so I can't run any Direct X 9 games? I'm trying to run GRID - and I'm getting the error message that the program can't start b/c d3dx9_41.dll is missing from your computer. Try reinstalling the program to fix this problem. Click to expand... I've downloaded all of the 3 latest patches and I'm getting no game load.
StrangleHold Moderator Staff member Mar 5, 2010 #9 Try this http://www.microsoft.com/downloads/...FamilyID=2da43d38-db71-4c1b-bc6a-9b6652cd92a3
J Jamin43 banned Mar 5, 2010 #10 StrangleHold said: Try this http://www.microsoft.com/downloads/...FamilyID=2da43d38-db71-4c1b-bc6a-9b6652cd92a3 Click to expand... That fixed it for me. :good: Thanks
lubo4444 Active Member Mar 5, 2010 #11 StrangleHold said: Try this http://www.microsoft.com/downloads/...FamilyID=2da43d38-db71-4c1b-bc6a-9b6652cd92a3 Click to expand... Does this still keeps the DirectX 11?
J Jamin43 banned Mar 5, 2010 #12 lubo4444 said: Does this still keeps the DirectX 11? Click to expand... Yes
