The_Other_One
Please consult the experts... Today was a major fail day for many people...
Case #1 - Guts were moved from one case to another. Worked before the move, no post
Solution #1 - No ATX12v plugged into the motherboard. Catastrophic hard drive failure (drive showing up in bios as bzbzbzbzb...)
Case #2 - New build using new and old parts. Computer won't do anything.
Solution #2 - Front panel wires go to proprietary connection which was plugged in the firewire header. All drives were IDE and set to master. Missing 12v power to the board.
Case #3 - Burning smell then no post. PSU tested fine.
Solution #3 - Customer inserted CPU incorrectly and bent the pins on the board.
And these were just a few things I came across today at work
