well its about time i find that info we were looking for
got this off this forum
http://forums.filefront.com/halo-problems-errors-help/320353-halo-2-xp-multiplayer-4.html
HALO 2 PRODUCT ID AND LIVE ACTIVATION INFORMATION GUIDE FOR WINDOWS XP
11/30/08 -
[email protected] - Games for Windows LIVE
INSTRUCTIONS ON HOW TO ACTIVATE THE PRODUCT KEY FOR HALO 2 ON WINDOWS XP
NOTICE: YOU MUST HAVE A LEGIT COPY OF HALO 2. PRODUCT ID KEY REQUIRED. HALO 2 MUST BE INSTALLED. NO DOWNLOADS ARE REQUIRED. CRACKS, PATCHES, OR ANY OTHER STUFF WILL MOST LIKELY NOT WORK. THIS WILL ACTIVATE YOUR PRODUCT ID KEY, ALLOWING YOU TO USE LIVE. HOWEVER, IT MAY BE CRASHY. HALO 2 PC WAS DESIGNED FOR VISTA, NOT XP, SO IT MAY NOT WORK FOR YOU, BUT IT MAY WORK FOR SOME. PLAYING HALO 2 ON XP MAY BE FINE ON SINGLE PLAYER, BUT IT MAY NOT BE FOR MULTIPLAYER. THERE COULD BE A WAY TO MAKE IT WORK FINE, SUCH AS SETTING HALO 2 AS HIGH PRIORITY OR FREEING UP RAM, OR A FIX THAT COULD MAKE IT LESS CRASHY AND LAGGY.
Download the latest LIVE version:
h2v.halomaps.org - Halo 2 Vista Maps files and Utilities Resource
Download the latest HALO 2 Version:
The product ID location is located in the registry, just like HALO. Go to the Start Menu > Run > regedit.
It should be located in My Computer/HKEY_LOCAL_MACHINE/SOFTWARE/Microsoft/Microsoft Games/Halo 2/1.0
If not, find your HALO 2 registry location or create it.
Right click and create a new PID string value in the 1.0 folder, if it doesn't work try creating the PID string values in other HALO 2 folders. In the Name column it should say PID, and the Data column should have the Product ID key.
After that, you've registered the Product ID Key. To check if it worked, start up Halo 2, go to Settings, and then About. It should have your Product ID there. (I jumped with joy when I saw it) :]
Start up HALO 2 and register for LIVE, it might take you to a broken link but go back in-game and try again/see. If you need to register or log in your LIVE account using a seperate internet browser see FAQ.
Then you should have LIVE and the Product Key activated.
FAQ (Frequently Asked Questions)
Q: Doesn't this violate the EULA of HALO 2?
A: GTFO!
Q: Does this work without a product key?
A: No.
Q: Where can I get a product key?
A: Buy one, or somehow get one.
Q: It's not working!
A: Try again.
Q: When I try to sign up for LIVE or log into LIVE in-game, it makes me minimize the game to sign up and the page it sends me to is not working.
A: Try going back in-game, or use the link below.
Q: Where can I sign up for LIVE or log into LIVE?
A: Sign In
Question not answered here? Contact
[email protected] -- Thanks to GameSpot Forums - Halo 2 - Attn: Anyone wanting to play Halo 2 XP using the Live service.
PLEASE SPREAD THIS AROUND THE INTERNET IF YOU WANT TO. KTHXBAI. Posting by user1500.
i think it will work. my halo 2 isnt comin for another 2-3 days but try it out :good:
