Windows 7 - finding large files
djchapple
I have a laptop running Windows 7 and I have my 240 GB HD set up with two partitions (C: and D:). I have also set up some backup software to backup both C: and D: to an external HD (F:).
However it would appear that the software is trying to backup drive C: to drive D:, instead of to drive F: and drive D: is now full.
I have had great difficulty finding where the backup file is stored on drive D: and my question is as below:
How can I find all large files stored on a hard drive?
I have tried simply looking through all the directories and after deleting many unused file I managed to delete the culprit but in many cases Windows explorer did not give the size of some of the files with weird file names.
Our software jv16 has a very good finding tools.
You can search by size.
Trial (full version) for 60 days is free :D
What sort of backup software are you using?
Are you sure you configured it correctly?
Acronis on-click backup.
No I did not configure it correctly but this has been corrected and so this particular problem will not arise again.
However I am still interested in being able to find the largest files on a disc so that I can see if some more space can be liberated.
Well this software doesn't search for big files but it does tell you where the most of your space goes.
http://download.cnet.com/WinDirStat/3000-2248_4-10614593.html
Freeware.
