I am building a new PC using i5. So far i came up with these parts, please take a look and let me know if any part can be replaced for about the same price with one that has better value. I am planing to run win7 64bit on this one.
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115215&cm_re=i5_750_processor-_-19-115-215-_-Product
Mobo: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131405&cm_re=asus_p55_pro-_-13-131-405-_-Product
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817341018&cm_re=700w_ocz-_-17-341-018-_-Product
Ram: http://www.newegg.com/Product/Product.aspx?Item=N82E16820227478&cm_re=ocz_platinum_4gb_%282_x_2gb%29_240-pin_ddr3_sdram_ddr3-_-20-227-478-_-Product
HDD: http://www.newegg.com/Product/Product.aspx?Item=N82E16822148395&Tpk=Seagate%20Barracuda
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811119202&cm_re=coolermaster_case-_-11-119-202-_-Product
GPU: this one either gonna be 9800gtx+ or hd5770.
I am planning to crossfire or sli in the future, depends on the cards.
And the case looks sexy to me ^_^(black and red,
yeah). So please help me review the compatibility between these components, hopefully everything will be fine.
Thanks guys.
Thanks guys.
