bomberboysk
As measured by anandtech:
I just hate ATI's drivers though, they are so annoying and I hate the catalyst control center. I had so many issues with it over the years I switched back to Nvidia.
I guess since ATI started publishing better open source drivers I may give them another chance.
the latest 10.3 drivers (at least the beta ones) are pretty good. some games get a nice boost in fps. i haven't had any problems with stability or anything like that. bezel management is cool. i never use ccc unless going from 2 desktops to eyefinity or visa versa.
edit: i see the official 10.3 drivers are released now.
So I did overload that silencer 610 with sli 285's and an oc'd i7 920![]()
Can't be right. I have two 275's and it shows that GTX 260 is using over 300w alone and gtx 275 around 400 w!!. How can that be possible when my two 275's use around 550-600w togheter under full load?
Edit: i just noticed that it said "Total system consumption". So, now im not sure... I don't know my total system consumption. Is there any way to measure this without opening my case?
You gotta use a kill-a-watt.
By the way noob, that is power consumption under furmark, which is basically as high of a load as you can get on a gpu.
You can get one on ebay for 20 to 30 bucks. I have one myself and it comes in pretty handy.
I checked my system with it and it uses 300 watts while running prime95 and furmark. While gaming, it uses 240 watts.
All those facts have been known for some time. The shaders and the crap yield count on the wafers. They either released what they had or nothing for many more months.
Semi accurate is the worst website on the internet in terms of legit information.
Sorry, i couldn't read it. Here's what your link consists of:
Edit: They probably deleted it.. no wonder..This is "semi" accurate after all..
