Can you not use the standard USB cable??? Just a thought.
What? The problem is where the cord meets the mouse. The actual USB plug is fine.
I think the connections for the usb on the mouse are soldered on, so any usb cord should work
They aren't. I've replaced the cord before.
Yeah, when the first cord died I thought it would be easy. Opened the mouse up and saw it had to be plugged in. I can't find anywhere to just buy a cord so I've been buying broken G5s haha.
I'll take some pictures soon... And my mouse is no where in that warranty any more.
so far it's only cost me 16 dollars to keep it going.
Albeit you are advertising in someone elses thread...Egons best path would probably be to buy your g500 quite honestly. Especially if he sells his G5 on ebay afterwards.For $40 you could buy a new logitech g500![]()
Ouch, looks like a ribbon cable which you wouldnt be able to solder. Beyond the ribbon cable, do you know if it goes back to standard solid/stranded copper wire? If so you could trace those back to the cable, strip a bit of the braided sleeving off, and then solder those wires directly to the pads on the printed circuit board inside the mouse.
Alright here are some shots of the actual cord connection itself.
The cord sheath is knit so stripping it wouldn't really work without ruining the whole sheath.
I still think 8 bucks for a whole broken mouse is fine. If it was just a cord I couldn't think it would be more than 4 dollars.
