Official Superpi Mod Ranking Thread
bomberboysk
This is probably pretty long awaited,but i've been working hard on getting a google docs submission setup for you guys.
What you must do to get your score listed:
  • Members Must have a minimum of 100 posts.
  • Members must use SuperPi MOD
  • These rankings are only for currently owned hardware, at time of submission.(Ex- if you sold your CPU before this thread appeared or before you submitted a score, it will not be accepted. However, your results will still stand if you sell the cpu after submitting a score)
  • A timestamp(open up windows date/time) must be in the screenshot.
  • Two instances of CPU-Z, one with the CPU tab open and another with the Memory tab open As of 6/7/2010 Memory Tab is Optional
  • An open Copy of Notepad with both the date and your computerforum username.
  • One result per CPU per user, however, users may submit results from multiple CPU's. If multiple results from the same CPU are submitted, the older result will be removed from the google docs database, if you have two CPU's of the same model, PM me.
SuperPi Mod can be downloaded from Here.
CPU-Z Can be Downloaded from Here.
There are two separate submissions, one for AMD processors and one for Intel processors, to separate the google docs spreadsheets. However, results will be combined for the "top 25" in this thread, in addition to the Top 50 intel and Top 50 AMD.
Results will be updated a minimum of once per week. Requests to update the thread will be deleted.
bomberboysk
Top 25
(INTEL+AMD)
Click here to submit scores for AMD processors.
Click Here to submit scores for Intel processors.
Formatted as follows: NAME (CPU/Clockspeed/Voltage/) [Time]
1. 87dtna (Core i5 2500K/5209Mhz/1.54) [7.213]
2. 87dtna (Core i3 530/5214Mhz/1.5875) [8.32]
3. 87dtna (Core i7 920/4893Mhz/1.52) [8.33]
4. 87dtna (Core i7 950/4756Mhz/1.5125) [8.58]
5. 87dtna (Core i3 550/4928Mhz/1.55) [8.690]
6. susik89 (Core i7 920/4531Mhz/1.36) [8.975]
7. 87dtna (Core i7 920/4620Mhz/1.55) [9.047]
8. meticadpa (Core i7 930/4503Mhz/1.458) [9.078]
9. Just a Noob (Core i7 920/4503Mhz/1.53) [9.094]
10. Jevery (Core i7 950/4200Mhz/1.352) [9.688]
11. Buzz1927 (Core i5 750/4337Mhz/1.5) [9.703]
12. Intel_Man (Core i7 920/4089Mhz/1.39) [9.969]
13. Remeniz (Core i7 920/4000Mhz/1.248) [10.294]
14. Domain_Man (Core 2 Quad Q9650/4500Mhz/1.54) [10.451]
15. Jevery (Core 2 Quad Q9650/4275Mhz/1.39) [10.983]
16. The Chad (i7 920/3398Mhz/1.192) [11.977]
17. El Gappo (Phenom II X6 1055T/5252Mhz/1.606) [13.197]
18. 87dtna (Phenom II X2 555/5033Mhz/1.725) [13.978]
19. Linkin (Pentium Dual Core E6300/4003Mhz/1.46) [14.31]
20. 87dtna (Phenom II X6 1090T/4830Mhz/1.8) [14.383]
21. Mihir (i7 920/2810.2/1.088) [14.407]
22. Nevakonaza (Core 2 Quad Q6600/3500Mhz/1.192) [15.116]
23. 87dtna (Phenom II X6 1055T/4508Mhz/1.625) [15.34]
24. Spynoodle (Core 2 Quad Q9650/3000Mhz/1.3625) [16.468]
25. FuryRosewood (Phenom II X4 955/3800Mhz/1.42) [18.532]
bomberboysk
Top 50
(AMD)
1. El Gappo (Phenom II X6 1055T/5252Mhz/1.606) [13.197]
2. 87dtna (Phenom II X2 555/5033Mhz/1.725) [13.978]
3. 87dtna (Phenom II X6 1090T/4830Mhz/1.8) [14.383]
4. 87dtna (Phenom II X6 1055T/4508Mhz/1.625) [15.34]
6. Aastii (Phenom II X3 720/3675Mhz/1.5) [19.283]
7. Rocko (Phenom II X4 945/3600Mz/1.4) [19.34]
8. jasonn20 (Sempron 140/3850Mhz/1.575) [19.797]
9. newgunner (Phenom II X4 925/3402Mhz/1.296) [20.422]
10. Drenlin (Athlon II X4 635/3822Mhz/1.52) [20.546]
11. Buzz1927 (Athlon II X2 440/3671Mhz/1.35) [20.811]
12. Drenlin (Athlon II X4 635/3654Mhz/1.39) [21.871]
13. Fatback (Athlon II X3 435/3610Mhz/1.5) [23.862]
14. Metallica17 (Athlon 64 X2 6000+/3006/1.232) [33.009]
15. Voyagerfan99 (Athlon 64 X2 3800+/2250Mhz/1.36) [41.532]
16. Gooberman (Athlon 64 X2 3800+/2009Mhz/1.1) [42.813]
17. Aastii (Athlon 64 X2 4450e/2300Mhz/1.665) [59.66]
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
49.
50.
Click here to view AMD Spreadsheet
bomberboysk
Top 50
(INTEL)
17. Linkin (Pentium Dual Core E6300/4003Mhz/1.46) [14.31]
18. Mihir (i7 920/2810.2/1.088) [14.407]
19. Nevakonaza (Core 2 Quad Q6600/3500Mhz/1.192) [15.116]
20. Spynoodle (Core 2 Quad Q9650/3000Mhz/1.3625) [16.468]
21. Voyagerfan99 (Core 2 Duo P8600/2400Mhz/0.875) [20.515]
22. Spynoodle (Celeron D 356/4757Mhz/1.6) [32.703]
23. Spynoodle (Pentium 4 520/3756Mhz/1.55) [37.469]
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
49.
50.
Click here to view Intel Spreadsheet
bomberboysk
Submission links are now active, and in the second post in this thread. Links to spreadsheets for Intel and AMD processors are now in their respective Top 50 lists.
Using the submission links to post obscene messages or fake scores will not be permitted, if you do such, you will receive either a profile warning or infraction.
Aastii
I'm going to post a score in here, but the screenshot I took for the last thread doesn't have the time or memory, even though I posted as I did it, so the time and date will be the same as the post, give or take 5 minutes, and memory was at stock. Will I have to get my CPU to those clocks again, test again (bareing in mind super pi is a little unstable even if the system is I haev found) and post up again?
Also, a quick question, why is time and date needed?
bomberboysk
To verify that you indeed have the CPU at the time of submission. Nearly everyone voted on new scores, so you'll pretty much need to do benches from today on out.
Preferably, everything in one screenshot, as the submission forms only have a single screenshot box(and to help verify memory speeds/timings/clocks at that speed).
Aastii
I'm pretty sure you know that my CPU is what it says it is, I posted about my system dieing and getting it in January after all and my new rig, and I mention it every now and again, I have it sat in my tower next to me, so do I need to redo my overclocks all over again, or can I use my other screenshot which has only CPU speeds, remembering I still have the system I used to bench it now, and everything but the CPU was stock
bomberboysk
I can't view the Intel Spreadsheet. Something's wrong.
Whoops, forgot to share that publicly, try the link now it should work.
No problem, i'll accept that score, just in the screenshot box place a space between your two url's with a current cpu-z screenshot(for continuity sake).;)
Amazing thread and nice thinking (google docs spreadsheet)
Just posted mine
I can't post your score until you fulfill all the requirements:p Read the first post in this thread to view all of what needs to be in your screenshot.
Also, for all AMD owners i just fixed the AMD submission sheet, forgot to add in whether or not the processor has been unlocked by asking number of active cores (which reverts it back to older microcode which is a touch slower).
mihir
will post when i reach india currently at my parents place in dubai where i dont have my PC
spynoodle
Very nice. Just posted mine. :) Can't wait to see some more scores up here. Hopefully I'll stay on the top 50 Intel. :eek:
bomberboysk
I'll update the leaderboards tomorrow, no use in continually updating them when the first day or so is when we'll get a majority of scores.
