Custom Build Gaming Machine [Feedback Please]
DreadlockBoy
Hey guys. This is my first post here and I've been reading some posts and the replies seem to be helpful so I thought I'd give it a shot. I'm not very smart with computers but I'd say I know some basics. I'm looking to build a gaming machine for Starcraft II, I do realize this computer I'm about to post is overkill but that's fine with me. I want this to last a while.
Things I'll be doing with this computer: Streaming online, playing Starcraft II, ventrilo, skype, HoN and other games with lots of internet browsers open! I'm also looking to spend less then $1,000, so anything less is fine with me.
Here are the specs, please give feedback and how I can change it up.
Motherboard:
--> ASUS P6X58D Premium LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Newegg Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131614R
Video/Graphic Card:
--> XFX HD-477A-YDFC Radeon HD 4770 512MB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
Newegg Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16814150369
Processor:
--> Intel Core i7-930 Bloomfield 2.8GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Desktop Processor
Newegg Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115225
RAM:
--> G.SKILL 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory Model F3-12800CL8TU-6GBPI
Newegg Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231247
Power Supply:
--> OCZ ModXStream Pro OCZ500MXSP 500W ATX12V V2.2 / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC Power Supply compatible with core i7
Newegg Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16817341016
Cooling (For processor I believe):
--> Tuniq Tower 120 Extreme Universal CPU Cooler 120mm Magnetic Fluid Dynamic LED Fan and Fan Controller/Heatsink Rev.1 with TX-3 & 1156 Brackets
Newegg Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16835154011
Computer Case:
--> Rosewill Smart One ATX Mid Tower Computer Case, Black interior, comes with three Fans-1x Front Blue LED 120mm Fan, 1x Rear 120mm Fan, 1x Top 120mm Fan, Option Fans-2x Side 120mm Fan
Newegg Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16811147120
--> CONCLUSION <--
I don't believe I'm missing anything out. I would really appreciate all of your feedback. I do intend to spend a bit of money so I would like some opinions other then my own and my friends, thanks again guys. PS- I have the 120mm PC fans covered for the case.
EDIT: The total of all of this comes out to 875$
the x58 motherboards run in tripple channel, in otherwords 3 sticks of ram
3x1gig 3x2gig etc etc (thats for optimal performance)
So basically, I should keep my 4GB of RAM and add antother 2 GB for the 3rd RAM slot? Thanks for the tip man 8-) anything else? I'm having a lot of doubt with my video card. I'd like to spend more then 100 but for the price, this is pretty boss from what I've researched.
well yeh you can do that, make sure its matching ram as it could make things difficult if they are different timings etc!
your psu look poor!
your rig seems to be a little un balanced, you have good componants mixed with poor quality stuff!
i know if it was me i wouldnt risk my componants with a sub par power supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171038
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139003
It will be more worth it, if you could put extra $10 for i7 930 as it is better and faster than 920: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115225&cm_re=i7_930-_-19-115-225-_-Product
Also, you should get more reliable PSU so that it will not blow up during your gaming. http://www.newegg.com/Product/Produ...9005&cm_re=corsair_650-_-17-139-005-_-Product
For your CPU cooling, this cooler will be much better: http://www.newegg.com/Product/Produ...uniq_tower_120_extreme-_-35-154-011-_-Product although it is quite expensive.
If you will exchange the parts I have suggested it will be a good gamin PC. You could change your graphic card as well, but it all depends on your overall budget.
your psu look poor!
New RAM:
--> http://www.newegg.com/Product/Image... Kit Desktop Memory Model F3-12800CL8TU-6GBPI
New PSU (I'm guessing, Power Supply unit?):
--> http://www.newegg.com/Product/Product.aspx?Item=N82E16817341016
The ram is a package thing, like you said, so they're all matching. And the powersupply has good reviews. My only concern is, is 550W going to be enough? I think my friend said I wanted 600+ (I know very little about PSU's)
are you running a tight budget?
if so 5670 is only a little bit extra!!
i would save and get the 5770 personaly
I was looking at the 5770 but a lot of the reviews are taking note of red lines that appear horizontally over the monitor after a month or two. So that issue kind of makes me a bit timid. My friend also was recommending the 5770 though.. I'll look up the 5670 right after this post.
I have a basic question. What is the difference between the RAM I linked in my original post (the ram of 3 sticks, 2 RAM each) and this:
http://www.newegg.com/Product/Produ...=False&VendorMark=&Keywords=(keywords)&Page=5
The above link is almost $20.00 cheaper for the same RAM. Same amount of gigs, same company, the only difference is a heat sync physical change and the color of the ram (lol). I'm thinking about switching to this and save $20.00
