Official 3dMark06 Rank Thread
bomberboysk
This is the Official Rank Thread for 3dMark06
What you must do to get your score listed:
  • Members Must have a minimum of 100 posts.
  • Members must use latest version of 3dMark06.
  • These rankings are only for currently owned hardware, at time of submission. Please provide a screenshot of two instances of CPU-Z(Memory and CPU Tabs), GPU-Z, an Open Copy of notepad with username and date, as well as a timestamp.
  • An open Copy of Notepad with both the date and your computerforum username.
  • One result per sytem(GPU+CPU) per user, however, users may submit results from multiple systems. If multiple results from the same system are submitted, the older result will be removed from the google apps database.
  • A valid ORB Submission link with your Username in the description or name of system is [strike]required[/strike] OPTIONAL.
  • Scores will be updated a minimum of once a week, please do not continually ask the scores to be updated.
Scores may be submitted Here
Ranks will include a Top 10 overall, Top 25 nVidia, and Top 25 ATi.
Spreadsheet May be Viewed Here.
Update January 17th 2011: A bolded and underlined L/N will be used beside a score to denote that the score came from a Laptop/Notebook.
Top 10 Overall
Scores are listed as follows:
(CPU/Clockspeed/GPU Model/Number of GPU Cores/GPU Core Clock/GPU Memory Clock) [3dmark Score]
1. 87dtna (Xeon X5667/4964Mhz/GTX 470/1/865Mhz/1830Mhz) [31663]
2. Jasonn20 (i7 2600K/5002Mhz/HD5870/1/1025Mhz/1300Mhz) [31565]
3. 87dtna (Core i7 2500K/5109Mhz/GTS 450/2/970Mhz/2050Mhz) [31146]
4. 87dtna (Core i7 920/4410Mhz/5850/3/950Mhz/1200Mhz) [30240]
5. jevery (Core i7 950/4312Mhz/GTX 460/2/832Mhz/2090Mhz) [27993]
6. Jasonn20 (Core i7 920/4515Mhz/HD5870/1000Mhz/1300Mhz) [27948]
7. jevery (Core i7 950/4200Mhz/HD4870/2/790Mhz/985Mhz) [26206]
8. 87dtna (Xeon L5640/4177Mhz/GTX 460 768mb/900 Mhz/2100Mhz) [25890]
9. Domain_Man (Core 2 Quad Q9650/4500Mhz/GTX580/1/772Mhz/1002Mhz) [25598]
10. 87dtna (Core i7 860/4200Mhz/GTX460 1GB/1/925/1000Mhz) [25433]
Top 25 ATi
(CPU/Clockspeed/GPU Model/Number of GPU's/GPU Core Clock/GPU Memory Clock) [3dmark Score]
1. Jasonn20 (i7 2600K/5002Mhz/HD5870/1/1025Mhz/1300Mhz) [31565]
2. 87dtna (Core i7 920/4410Mhz/5850/3/950Mhz/1200Mhz) [30240]
3. Jasonn20 (Core i7 920/4515Mhz/HD5870/1000Mhz/1300Mhz) [27948]
4. jevery (Core i7 950/4200Mhz/HD4870/2/790Mhz/985Mhz) [26206]
5. jevery (Core 2 Quad Q9650/4230Mhz/HD4870/2/810Mhz/985Mhz) [24231]
6. Sslaglez28 (Phenom II X4 955/4300Mhz/HD6950/1/950Mhz/1450Mhz) [22959]
7. The Chad (Core i7 920/3400Mhz/HD5870/1/900Mhz/1300Mhz) [22339]
8. joh06937 (Phenom II X4 955/3815Mhz/HD5970/2/850Mhz/1200Mhz) [21403]
9. Jasonn20 (Phenom II X6 1055T/4050Mhz/HD4870/1/870Mhz/1030Mhz) [20297]
10. Jasonn20 (Core i7 920/4305Mhz/HD4870/1/870Mhz/1030Mhz) [20200]
11. Bacon (Phenom II X4 940/3625Mhz/HD4870/2/790Mhz/980Mhz) [19984]
12. Jluchinski (Core i7 920/2670Mhz/HD5850/1/775Mhz/1125Mhz) [18934]
13. lubo4444 (Core i7 920/2678Mhz/HD5870/1/850Mhz/1200Mhz) [18543]
14. Nevakonaza (Core 2 Quad Q6600/3500Mhz/HD4890/1/910Mhz/1010Mhz) [16848]
15. linkin (AMD Athlon II X4 635/3480Mhz/HD5770/1/930Mhz/1300Mhz) [16401]
16. linkin (Pentium Dual Core E6300/4003Mhz/HD5770/1/1000Mhz/1400Mhz) [16282]
17. Gooberman (Athlon II X4 640/3330Mhz/HD5770/1/998Mhz/1338Mhz) [15676]
18.
19.
20.
21.
22.
23.
24.
25.
Top 25 nVidia
2. 87dtna (Core i7 2500K/5109Mhz/GTS 450/2/970Mhz/2050Mhz) [31146]
3. jevery (Core i7 950/4312Mhz/GTX 460/2/832Mhz/2090Mhz) [27993]
4. 87dtna (Xeon L5640/4177Mhz/GTX 460 768mb/900 Mhz/2100Mhz) [25890]
5. Domain_Man (Core 2 Quad Q9650/4500Mhz/GTX580/1/772Mhz/1002Mhz) [25598]
6. 87dtna (Core i7 860/4200Mhz/GTX460 1GB/1/925/1000Mhz) [25433]
7. 87dtna (Core i7 860/4517Mhz/9800Gx2/2/720/1152Mhz) [25335]
8. 87dtna (Core i7 860/4000Mhz/8800GTS(G92) 512Mb/2/783Mhz/1102Mhz) [23201]
9. 87dtna (Athlon II X3 435/4018Mhz/GTX295/2/725Mhz/1100Mhz) [20106]
10. Linkin (Athlon II X4 635/3625Mhz/GTX 460/1/800Mhz/2000Mhz) [18106]
11. Laquer Head (Core i7 740QM/2527Mhz/GTX 460M/1/675Mhz/625Mhz) [12309] L/N
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
I want to submit mine,But where the hell do i get the orb link from?
i dont understand?
this all sounds like too much hassel for a few numbers :(
ill do it eventualy, when i can be bothered
Well, somewhat of the goal is more than just rankings, but also being able say, compare performance between your system and someone who has a similar system to yours, which a detailed system profile helps accomplish.
i think the orb submission link thingy is a bit OTT,but okay...ive submitted bomber,I hope i done the link thing right...not doing it again :P
Set your result to public and you'll be good;)
Linkin...yours needs to be set public as well;)
(Orb is to ensure you arent running modded drivers or non default resolutions or such).
Edit: Looks like you got it set public.
In the future everyone, make sure to use the "compare" link as well;) Nevakonaza, i edited your submission for you to include the compare result;)
Yeah i set to public,So is that it? is it all good for the submission requirements now?
Jevery, you just posted your session URL from orb, you need to create an account, make the result public, and then use the "compare" link.
Well it looks like the session link I saved no longer leads to the test results and can't be recovered.
Apparently my machine's more capable than I am. Just delete my submission I guess. :(
If you logged into orb when you posted that, it should automatically be in your "my results" on orb.
@linkin, got it.
