Yeah this one is pretty much all I need. I was considering buying it then decided against it because it says on Newegg that you can use 1600 MHz ram through OC but according to Asus website it works natively so I'll probably end up buying this one.Not a fancy board but still a good choice IMO. I have had no problems with it.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131603
Thanks for that!
That's probably a silly question but I've downloaded the manual of that board and in the memory qualified vendors list there are 3 G Skill references :
* F3-12800CL9D-2GBNQ
* F3-12800CL8T-6GBHK
* F3-12800CL9T-6GBNQ
The one I'm buying is F3-12800CL9D-4GBRL.
What do the 2 last letters mean ? Can there be compatibility issues ?
