Bad Company 2 Thread
^ hah
Post up your stats!
whats up with people putting down anti tank mines on the bombs in Rush, thats cheating in my book.
Yeah i also noticed that,Another way that people are cheating is sitting in a tank and just keep on shooting the building with the bomb inside,then obviusly it collapses and the bomb is gone.
I think they should highly reduce the damage the tanks can do to the buildings that the bombs are inside to prevent this cheat.
Theres always someone doing it on the map Isla,because the tank can be far enough away that its hard for people with rocket launchers to take them out...yet its an easy range for the tank :/
Then your team should go run and plant C4 and or anti tank mines around it. Problem solved.
^ hah
Post up your stats!
Those are good stats, great kill / death ratio but Win Loss is average, that just shows its hard to get a good team, How did you get to that screen , Ill post mine when I get home from work... I bet im below .500 for kill death :)
Did you just do I printscreen in game then paste in photoshop too?
But if they stay far back enough....they can see enemy sneaking on foot and boom....theyre gone,You dont always have the oppertunity to plant AT mines either....,Also there will most likely still be enemy snipers on the hills on the centre island so they can take you out...if you have a good team then its easier but 9/10 there isnt realy any teemwork anymore.
Too many people are too intrested in their K/D ratios rather than doing teamwork with this game. :(
@mtb - thanks! :) My win/loss rate is crap on all my online fps's - im a bit of a white knight when it comes to team balance, always prefer to be on the loosing side, well, thats my excuse!
http://bfbcs.com/
Go to Graphics, go to 'Get this graphic' on a graphic you like, and search your name. Then just paste the link as an image onto the forum!
With regards the tank/mcom situation, a good enough team will tag a tank (there isnt anywhere on any of the maps where a tank is untouchable and can still take out the mcom) within seconds of the game starting.
Its all down to decent teamwork imo, a team of long distance snipers for example, serious problem. I agree about the mines, but not C4 - it takes 2 runs at the mcom, with the extra explosives and the explosive damage perks to take out an mcom, thats pretty hard to do.
Agree about the teamwork, its pretty lacking on a lot of servers, but means when you hook up with a decent set of players, its even more rewarding
To anyone that says default weapons are garbage.
I got platinum for both the MG3 and 9A91 Avtomat. So long as you know how to use a weapon you can do very well with it.
Patch is coming out tomorrow(that's what EA says) 890mb patch. They're also nerfing the An94
Someone posted this on reddit in the BC2 section.
Then I ran my BC2 Updater and it noticed a new update, and it's taking a little to install, so I'm sure it's the large one.
Ah yes about time we had an update,...ive not tried BC2 yet since the update but heres the changelog for those who have not seen it yet :)
The one in red = About time!!!!
steam said:
Changelog:
Server - Some potential sources for lag/rubberbanding have been eliminated
Server - The old reserved slots has been replaced by a kick-on-demand system like in BF2
Server - Log file for server admins: all remote admin interface commands/events are logged
Server - Log file for server admins: major server events + all chat messages are logged
Server - Idle kick is controllable
Server - Profanity filter can be disabled
Server - Teamkill-kick system is controllable
Server - Ticket counts and bleed rate are controllable per-level
Server - Infantry only mode available per-level
Server - Initial spawn delay and respawn delay are adjustable
Server - Server description can be up to 400 characters, and use "|" for line breaks
Server - Banlist can contain up to 10.000 entries
Server - reduced latency in packet handling
Admin Interface - fixed the player.onKill spam that occasionally happened
Admin Interface - ensured that player.onJoin events always report the player name
Admin Interface - events triggered when people spawn
Admin Interface - much more info on kills
Admin Interface - detailed stats are reported at end-of-round
Gameplay - Various minor level bugfixes
Gameplay - Helicopter handling has been tweaked
Gameplay - Weapon tweaks have been implemented based on PC public feedback
Gameplay - Tracer dart gun speed has been changed from 300 m/s to 200 m/s
Gameplay - Fixed technical hang when a crate was armed outside of the combat area
Gameplay - "Victory is near" message was shown for the wrong team on Valparaiso, this has been fixed
Gameplay - Countermeasures can be fired when driving a helicopter
Gameplay - The brightness of the pilot view in the Russian helicopter has been reduced
Gameplay - Advanced Spotting scope works better
Gameplay - Knifing people in the back works again (we backed out the change that we had done for Server R11)
Gameplay - Hit box for moving targets expands based on the speed of the targets movement
Gameplay - G36 now has crosshair when in Hardcore mode
Server Browser - Servers are sorted into 3 categories: Normal, Modified, Hardcore depending on their settings
Server Browser - Added support for retrieving update progress
Server Browser - Now refreshes information
Server Browser - Join queue system when attempting to join a full server
Server Browser - All settings are automatically saved between sessions
Server Browser - Pings are sent via an alternate mechanism, which should work for non-Administrator users as well
Client - Fixed DX9 issue, which likely caused graphics glitches and perhaps crashes
Client - Fixed some crashes
Client - Toggle/hold crouch is user controllable
Client - Toggle/hold zoom is user controllable
Client - Vsync bugfixed for DX10/DX11
Client - Rewritten how settings are written to disk; this should reduce/eliminate the spawn lag
Client - Fixed bug where a player could join a server before the stats has been downloaded causing faulty stats in "EOR- unlock progression"-screen
Client - New chat system allows chatting when dead (but not during end of round) and keeps a 100 lines log
Client - Improved Play Now functionality
Client - Removed K/D ratio and Skill Level filters in the leaderboards
Client - Any points you get while being dead will be added to your score
Client - Reduced negative mouse acceleration
Client - Increased health on the Cobra to match other vehicles
Client - More informative disconnection/kick reasons
Client - Support for Map Packs so PC gets future VIP maps at the same time as consoles
The Balance tweaks are as followed:
Slightly increased the damage of the UZI at long range.
The AKs74u now has more felt recoil when aiming.
The G3, VSS, and all SemiAutomatic rifles now settle slightly faster between shots when aiming.
The PKM, Type 88LMG, G3, An94, and 40mm shotgun have returned to their former glory.
Increased the damage of the MG3 to bring it in line with the rest of the LMGs.
Fixed a bug where the Saiga12 with slugs would do too much damage at long range.
Fixed a bug where the SVU would do too little damage at long range.
Fixed a bug where M95 rounds would not kill armored targets with headshots.
I love this game , I love playing RUSH but it kills my K/D average, I always sprint toward the bomb and get killed.... I dont know why I care.. I just hate it when my teamates sit back in use sniper rifles, no one plants... It makes me want to punch everyone on my team in the face
I love playing this game but onslaught was a waste of money and their time... it wasnt much of a challenge really it was like playing online just with stupid robots that i ran through with a group of guys in under an hour and 8 free achievements lol
Anyone been able to play yet? i still get "This game is currentlyuy Unavailable" :o
I haven't been able to play it because my DVD drive is deciding to throw a wobbler and not even open or be recognised or do anything. It has power to it, but it would appear it doesn't, so no updates or playing for me just yet :(
@aastii
why do you need your cdrom drive to play? gotta use steam brother! love steam, when I moved to germany I could redownload all my games :) and not worry about paying those outrageous european prices for games
