bkribbs
Hey, sorry we took a bit getting to you. I looked it over but dont see anything malicious. Has she been having problems? Though there are several items which could be eliminated for speed.
Uninstall the yahoo toolbar
In hijackthis place a check mark by each of these, then click the "Fix Checked" button.
O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\qttask.exe" -atboottime
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Common Files\Java\Java Update\jusched.exe"
O4 - HKCU\..\Run: [MSMSGS] "C:\Program Files\Messenger\msmsgs.exe" /background
O4 - HKCU\..\Run: [SUPERAntiSpyware] C:\Program Files\SUPERAntiSpyware\SUPERAntiSpyware.exe
Then restart and re-run hijackthis and post the new log.
You should create a recovery CD when HP prompts you to at startup. And you should actually use DVD's, not CD's to do it.
And if you want, post a program uninstall list from HiJackThis In "Misc Tools" --> "Uninstall Manager" --> "Save List" button then save and copy, then paste it here.
I swiped this from another thread on here. What does placing the checks there do? Does that remove them from startup? I know those aren't viruses so I was just wondering.
