Yeah looks like two slots on the motherboard died in the swap. ECS is known for being pretty crappy sorry to say. Time to upgrade!
You bought it new? Should have some kind of warranty.
Static charge most likely, or broke a trace from flexing the board.
Going from a socket 939 is a bit of a pain, but you should really upgrade completely. Do you have any kind of budget in mind?
I'm guessing your 3650 is AGP, so you'll even need a new video card too. You also only have ddr1 ram, so you can't even re-use that either.
I'll try keeping this as cheap as possible, but still good hardware and upgradeable-
Motherboard-
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157176
CPU-
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103698
Ram-
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148194
Power supply-
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139017
Video card-
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150450
And a SATA dvd burner since all new motherboards only have 1 IDE port which you'll need for your hard drive-
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106333
Thats around $300 for a PC thats soooooo much better than what you have now. And very future upgradeable! You're going from ddr1 to ddr3, from socket 939 to AM3, from AGP to PCIe 2.0, from a 3650 to a 4670 which is a huge step, with this setup you'll be able to play most modern games at decent resolution.
OK well I may have found a cheaper alternative anyway. If you get this board here-
http://www.ebuyer.com/product/170230
Just use the onboard graphics until you can afford a good graphics card. The onboard is pretty much as good as your current AGP 3650 anyway.
ram-
http://www.ebuyer.com/product/152979
CPU-
http://www.ebuyer.com/product/168975
Power supply-
http://www.ebuyer.com/product/150985
DVD burner-
http://www.ebuyer.com/product/176026
Thats only 200 pounds for a complete overhaul upgrade. Not bad at all! Keep saving then for a decent video card, like a 5770 or something and you'll be all set. Future upgradeable to better AM3 cpu's, including the new Hex core, and of course you can always get more and better ram.
You can try and sell your current system as a set with 2x512mb of ram and state that two slots on the board don't work, you may get ~$40-50 back.
