Can you access the Task Manager?
It sounds like you had/have a virus.
Stick in your install cd and reboot, use the repair console to fix anything thats missing (should be able to auto detect problems)
Unless you've got a Dell, Hp or other large manufacturers system, then use the system restore software loaded.
Using windows system restore might work as well, as long as you can remember when this started happening
