Proposed Tech Guide: Build Budget Recommendations - Draft
I agree with what bomber said. I'll also volunteer to maintain one speciality build. probably mid-range/bang for buck gaming.
ok this is what I came up with for HTPC
Basic HTPC
Silverstone GD04 - $99.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811163158
Gigabyte GA-H55M LGA 1156 Micro ATX Motherboard - $74.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128450
Intel Core i3-530 2.93Ghz 73 watt Dual Core CPU - $113.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115222
Kingston ValueRAM 2GB DDR3 1066 Memory - $37.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820134793
Gigabyte Radeon HD 4550 PCI Express 2.0 X16 Video Card - $49.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125250
Western Digital Caviar Blue 640 GB Hard Drive - $69.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136218
Asus Xonar DS Sound Card - $49.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16829132013
Hauppauge WinTV-HVR 1850 PCI-Express HD TV Tuner - $119.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16815116015
Asus Black DVD Burner - $18.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
Corsair 450VX 450 Watt Powersupply - $69.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139003
~$700
Standard HTPC
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128430
Gigabyte GA-H57M LGA 1156 Intel H57 Micro ATX Motherboard - $119.99
Intel Core i3 3.2Ghz LGA 1156 Dual Core CPU - $129.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115065&cm_re=i3_550-_-19-115-065-_-Product
G. Skill DDR3 1600 4GB Memory - $84.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
Zotac GeForce GT 240 PCI Express X16 Video Card - $95.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814500138
Wester Digital Caviar Black 1TB SATA Hard Drive - $87.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136284
Asus Xonar D1 Sound Card - $89.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16829132007
Cooler Master GeminII Heat Sink - $39.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103046
Lite-ON Blu Ray Drive - $47
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106325&cm_re=blu_ray-_-27-106-325-_-Product
~$1000
Top of the Line HTPC
LUXA2 LM200 Micro-ATX HTPC Case - $359.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133082
Intel Core i5 3.2Ghz LGA 1156 Dual Core CPU - $179.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115220
PowerCooler HD5750 Passive PCI 2.1 X16 Video Card - $169.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131346
Western Digital Caviar Green 2TB SATA Hard Drive - $119.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136344
OCZ Agility 2 60GB SSD - $159.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227542
HT Omega Clara Plus Sound Card - $174.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16829271003
LG Blu-Ray Burner - $99.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136181
Corsair 650TX 650W Power Supply - $119.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
Noctua NH-C12P 140mm CPU Cooler - $73.00
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608019
Noctua NF-S12B 120mm Fan - $24.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608009
~$1900
Basic HTPC
~$700
Standard HTPC
~$1000
~$1900
Those all look really good, thanks! I'll add them now.
A few suggestions:
1) I'd separate sound cards into two sections, Audio and Gaming. The X-fi's are good for gaming, but for music...there are far many better choices.
2) I'd Separate sections/builds with Bolded/underlined fonts that are larger than the rest of the text(size 4 would probably work well), and then bold prices as well. No offence, but right now its pretty difficult to read.
