Just got it up and running.
I put together my old computer about 6 years ago. It was a champ. About the only problem was the fan on the CPU died a couple of years ago, luckily the ASUS board shut down when it got hot. Hope my new one lasts as well as it did.
My new build:
OS Suse 11.3 64bit http://software.opensuse.org/113/en
MOBO ASUS M4A88TD-V EVO/USB3 http://www.newegg.com/Product/Product.aspx?Item=N82E16813131646
CPU Athlon x4 3.0 http://www.newegg.com/Product/Product.aspx?Item=N82E16819103871
CPU cooler http://www.newegg.com/Product/Product.aspx?Item=N82E16835103046
HDD Samsung 1TB http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
HDD cooler http://www.newegg.com/Product/Produ...m_re=hard_drive_cooler-_-11-999-152-_-Product
Video card GT240 http://www.newegg.com/Product/Product.aspx?Item=N82E16814500138
Memory, 8 Gigs http://www.newegg.com/Product/Product.aspx?Item=N82E16820226095
PSU Corsair 650W http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
DVD burner http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289
I used an old no-name case about 8 or 9 years old I had lying around. Nothing fancy. Best thing about it is it is a nice elegant beige color, those are getting hard to find
I broke out the hole saws and installed a bunch of fans in it, it runs nice and cool, and fairly quiet. I installed a front panel to fill the floppy hole http://www.newegg.com/Product/Product.aspx?Item=N82E16811996006
I set up the SATA controller for AHCI. I will probably add a SSD at some point. Everything is working well. I like it.
My new build:
