Ankur
Okay my friend wants to build a PC at home, I will be helping him, as it is his first built.
Will use it for Heavy Gaming.
Budget 900 USD to 1100 USD.
Would be good if comes under 900.
1. CPU
Intel i7-950, 4 Cores, 3.06GHz to 3.33GHz.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115211
294.99 $
or please suggest an AMD processor if you think it is cheaper and better.
2. Mobo
ASUS Sabertooth X58 LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131665
199.99$
is it compatible?
What about Intel, Gigabyte?
Please suggest which ever is better.
3. Memory
CORSAIR DOMINATOR 8GB (4 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMP8GX3M4A1600C8
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145314
$209.99
Is it compatible?
What about G. Skill and Kingston?
3. Hard Drive
Seagate Barracuda 7200.12 ST3500418AS 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148395
$49.99
Is it compatible?
What about Samsung or others?
4. GPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121390
$169.99
ASUS ENGTX460 DirectCU TOP/2DI/768MD5 GeForce GTX 460 (Fermi) 768MB 192-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
Why can't I get GeForce directly manufactured by Nvidia?
How about Radeon? is there a cheaper one?
5. HSU? Fans? monitor?case?
He will be using his old fans, case, monitor, keyboard, mouse, speakers (All 5 year old), will they be compatible? Please tell me if you need more details about them.
6. Microsoft Windows 7 Home premium
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116716
$176.99
7. PSU
Will the old PSU handle the new parts? Please suggest me PSU, till then I will get details of the old one.
The total cost goes upto 1102 USD, please suggest me better or cheaper parts to get the cost a bit down (atleast 50 to 100 $).
1. CPU
294.99 $
2. Mobo
199.99$
is it compatible?
3. Memory
$209.99
Is it compatible?
3. Hard Drive
$49.99
Is it compatible?
4. GPU
$169.99
$176.99
7. PSU
