Do you have keyboard. mouse?
What about os, want 7?
What's the make and model of the hdd you already have?
Where can you buy from?
When will you purchase the parts?
ok! Having that stuff already helps a bunch.
AM3 on that MB means the cpu socket type and thats AMD's most surrent,,,so the i5 won't fit.
For the budget you'll bet more bang with AMD.
There's better RAM for the same or a tad more.
What gpu do you have?...while we help shop
EDIT: is your os on disc?
Let us know if you don't want to mess with rebates, and let's get some input from other members on this as something better may be found. Keep your 4670 for back-up. Didn't add the ship but it won't be much.
$495 - No CF. $221 - 955/87TD
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.573157
$70 - Rj 1600/C7
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231303
$140 - Asus 5830
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121367
$64 - Antec 520
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371030
$553 - With future CF, (5850 vs 5830) a little over budget w/case, :
$233 - 955/87TD EVO
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.564823
$250 - XFX combo
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.564104
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL
52.99$
I have 9 myself. But if you could get 9 or 7, which one you you get?Benny, that guy seems to really like faster Cas Latencies.
i raised my budget to $600 because i got money from christmas. ill be picking these up so can you guys pls make sure that they're compatible with each other and that im paying the best for whatever im getting. help is MUCH appreciated
mobo http://www.microcenter.com/single_product_results.phtml?product_id=0327057
cpu http://www.microcenter.com/single_product_results.phtml?product_id=0341729
ram http://www.computerforum.com/188129-budget-computer-build-help.html
case http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233
video card http://www.newegg.com/Product/Product.aspx?Item=N82E16814130591
psu http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
