I'm a huge gamer but I've never built a custom rig before. I finally have what I think is a sufficient amount of money in order to do so. Can somebody give me all the parts that are needed in order to build a computer?
And what's thermal paste?
I would also add a Power Supply, Monitor, Keyboard, Mouse, Anti static wrist strap and a CABLE FOR THE SATA DRIVE. d'oh, now I'm waiting again...
Are there any other cables that are needed when building a computer? I have ordered all the parts listed above. Will I need any other cables?Oops
Forgot about the PSU and peripherals, but peripherals are obvious, I think the OP meant what goes inside the case. Anti-static wrist strap isn't necessary as long as you don't build on carpet and discharge any static you may have onto the case before the components go in. Nearly all SATA drives (optical and HDD) come with all cables needed.
Is there another thread where you've listed the parts you ordered? Are you sure they are compatible? If not, pls list the brands and models.I have ordered all the parts listed above.
