Computer case, Power supply and Heatsink; Need help!
computer111
Hello,
I will be building a gaming rig soon and I needed help with a couple of things. During boxing day I bought parts from different stores and now I'm starting to question the compatibility of my components. Here are a few questions I have and I am a beginner in the computer world so what I say may not make complete sense:
1. I made some research and found out that the video card I ordered requires a minimum of 34A from the 12v rail of the power supply (http://forum-en.msi.com/index.php?topic=104805.0;wap2). Please note that the GPU needs to be plugged with a 6 pin and a 8 pin PCI-E connector. I also realised that the power supply I ordered have multiple 12v rails of low amperage (25A). Does the 6 pin and 8 pin PCI-E connectors use there own 12v rail and would this mean I'll be fine? or do I need to exchange my PSU for another one with a single 12v rail that has more amperage? If so would this one work: http://www.newegg.ca/Product/Product.aspx?Item=N82E16817139006? Remember that I am looking to get the maximum performance out of my video card.
2. Do you think that my heatsink and huge video card will fit in my case?
3. Should my heastink cool my CPU enough?
Here’s my parts list:
- Case: COOLER MASTER Storm Sniper SGC-6000-KXN1-GP Black Steel, ABS Plastic, Mesh bezel ATX Mid Tower Computer Case
( http://canadacomputers.com/product_info.php?cPath=6_112&item_id=027792 )
- Motherboard: ASUS Rampage III Gene LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
( http://www.canadacomputers.com/product_info.php?cPath=26_342&item_id=032569 )
- Memory: Patriot Viper II Sector 7 Edition 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 2000 (PC3 16000) Desktop Memory Model PV736G2000ELK.
( http://www.newegg.ca/Product/Product.aspx?Item=N82E16820220500 )
- CPU: Intel Core i7-950 Bloomfield 3.06GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Processor BX80601950
( http://www.newegg.ca/Product/Product.aspx?Item=N82E16819115211 )
- Power Supply: Antec EarthWatts EA750 750W Continuous Power ATX12V version 2.3 SLI Certified CrossFire Ready 80 PLUS Certified Active PFC "compatible with Core i7/Core i5" Power Supply
( http://www.newegg.ca/Product/Product.aspx?Item=N82E16817371026 )
- Hard Drive: Western Digital Caviar Black WD6402AAEX 640GB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
( http://www.canadacomputers.com/product_info.php?cPath=15_210_212&item_id=030967 )
- Video Card: SAPPHIRE 100311SR Radeon HD 6970 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
( http://www.newegg.ca/Product/Product.aspx?Item=N82E16814102915 )
- CD/DVD drive: ASUS Black 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 24X DVD Burner
( http://www.newegg.ca/Product/Product.aspx?Item=N82E16827135204 )
- CPU Heatsink: COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible Intel Core i5 & Intel Core i7
( http://www.canadacomputers.com/product_info.php?cPath=8_129&item_id=025125 )
- Monitor: ASUS VE247H Black 23.6" 2ms Full HD HDMI LED BackLight LCD Monitor w/Speakers 300 cd/m2 10,000,000:1 (ASCR)
( http://www.newegg.ca/Product/Product.aspx?Item=N82E16824236112 )
Any kind of help would be appreciated,
Thanks!
I have heard that single raid PSU's are better but I have no experience of my own. Your PSU isnt modular, so it might be a little harder to get you cables run and a real clean look from it. According to the specs of your case its 254.6mm wide, and your heatsink is 158.5mm high, i dont see why it wouldnt fit theres about 100mm to play with... note that the MOBO space takes up so of that 100mm too, but it should fit. If you not overclocking the heatsink should be fine, again no personal experience, but I have researched tones of heatsinks for my build and i went with http://www.newegg.com/Product/Product.aspx?Item=N82E16835233029
after mail in rebate its the same price as yours, and havent heard a bad review i believe yet.
That CPU Cooler is not adequate. Get a CoolerMaster V6GT and some Arctic Silver 5 thermal compound.
Everything else looks solid.
If you want to save some money, buy a 6950 and flash it to a 6970 for free. Those cars have Dual BIOS so if you screw up no problem
if hes not overclocking this heatsink is fine, we must find out if hes overclocking or not, correct?
It should alright then. But if you want a quiet and cool system, I'd get some Arctic Silver 5 paste, an ArctiClean kit and some good fans for the 212+
for my Hyper TX3, I got 2x Scythe Kaze Jyu 2000RPM fans (92mm/100mm) and they are dead quiet, they are plugged into the motherboard so running about 1600rpm
But I think the 212 uses 120mm fans.
Now I dont need a thread on what fans to buy.... good advice sir
