Hi some upgrading help needed running a 32bit
dellxps420
banned
Hi im running a 32bit on my xps 420 i was just wondering how would i go about upgrading to 64bit im using vista home premium. Any help is well appreciated
I found this:
From Dell - you can request a 64-bit version of your OS through Dell, but you have to invoke a special "DSN Document ID 158098" rule with Tech Support, and it sounds like they won't always accept it, or it might take a long time.
Sounds like that ^ route or buy the 64 bit os.
I found this:
but why dont i do the simple way reinstall vista and in the custom installation select 64bit how does that sound ?
The disc only come with one bit type. I think you'll find that $ is the only way to get 64 bit on there. Newegg has 7 home for $100. I didn't look for vista.
Yep your wright its only for the 32bit ill check on eBay for a 64bit as i will need to update sooner or later but does all the driver ect come build in that cd and ill just get mu uncle to sort it out as he is like an expert on computer lol lucky me :P
