gamerwithoutrig
Hey, was just mixing and came up with this:
Sapphire Radeon HD 6950 2GB GDDR5
PCI-Express 2.0, 2xDVI, HDMI, 2xmini-DisplayPort
Microsoft Windows 7 Pro EN
OEM, 64bit
Samsung SpinPoint F3 1TB
7200RPM, SATA 3.0 Gbps, 3,5", 32MB Cache, 8.9ms
Fractal Design Define R3 Black Pearl
Fans: 1x 120mm Front, 1x 120mm Bak, Soundabsorbing, ATX, mATX, mITX
ASUS M4A87TD EVO, Socket-AM3
ATX, AMD870+SB850, DDR3, 2xPCIe(2.0)x16, SATA 6Gb/s, USB 3.0
NZXT HALE 90 Series 750W PSU
ATX 12V V2.2, 80 Plus Gold, Modular, 2x 6pin+2x 6+2pin PCIe, 8x SATA
BenQ 24" LCD G2420HD
1920x1080, 40000:1, 2ms, VGA/DVI/HDMI
Corsair H70 Hydro Series CPU Cooler
Socket 775/1155/1156/1366, AM2/AM2+/AM3, 1600~2000 RPM, 120mm Fan
Arctic Silver Ceramique Thermalpaste
2.5 gram
Akasa SATA3 Cable 100cm Dark
SATA III (6.0Gb/s),SATA II (3.0Gb/s) and SATA I (1.5Gb/s), SSD, 7pin
Sony Optiarc DVD±RW burner AD-7263S
DVD±R: 24x max, DVD±RW: 8x max, DL, RAM, SATA, Labelflash, Bulk, Black
AMD Phenom II X4 965 Black Edition
Quad Core, 3,4Ghz, AM3, 8MB, 125W, Boxed
Corsair Vengeance™ DDR3 1600MHz 8GB CL9
Kit w/2x 4GB XMS3 modules, CL9-9-9-24, 1.5V, Vengeance Heatspreader, 240 pin
Is there something I should change?
He will be using it for gaming, some writing programs and some movie editing.
edit: Some Norwegian words.
OEM, 64bit
2.5 gram
