Missing wireless network icon in system tray
_Lynn_
Yesterday when I was starting up the computer, I think the plug was loose or something and during the middle of starting up the computer just went off by itself. After turning it on again and logging in, I found that the wireless icon was gone (the one that looks like a radar with green bars indicating signal strength) in the system tray. I've tried the following already but nothing works:
- Disable/re-enable wireless in device manager
- Restart the computer
- Enable icon display in network connections -> wireless network properties
Windows is able to detect the wireless networks properly, however the signal strength is "low" (which is not normal as I usually have good or excellent signal strength), and browser occasionally freezes/hiccups in connection. Also if I try to access Intel PROWireless utility, nothing happens when I click it in program files, so something's definitely wrong with the wireless.
Screen 1:
Screen 2:
Screen 3:
Does anyone know how to get that icon back? Thanks.
It looks like you may have partially fried the wireless card. You may want to uninstall the wireless software in add/remove programs and then reinstall the latest driver for the wireless by going to the laptop manufacturers support website.
Thanks. I reinstalled the driver through add/remove programs and now it's working fine. :)
It was probably broken as I took apart the laptop fan yesterday to clean the dust off, but did not reapply the layer of heatsink cooling gel, so the laptop probably overheated.
